victor9999
Hi,
I am curently installing 1 in EMT for Fiber Optic cables. At the end of each run, we would install less than 3 ft of 1 in FLEX to a 4x4 box riveted to a Jiffy pole leading to Office furniture. My 1 in EMT is grounded at the Comms Closet
(Grounding Bus Bar).
Problem:
NEC states that FLEX is not a reliable ground. Therefore a 14 AWG ground wire should be used to bound the 1in EMT (at the last pull box) to the 4x4 box on the top of the jiffy pole.
My flex is not used between sections of Conduit. This is the last 2-3 feet of the run. The furniture has electrical wires going in through another jiffy pole and the electrical ground is provided through that path.
I am sick of having this guy on my ass so I intend to find something in writing.
There must be an exeption to FLEX when it is used in the last section of a run and is connected to a jiffy pole.
thanks for your help
Problem:
