Grounding to baseboard radiant heat copper pipe
Shock96
New member
Olympia, WA
Hi all. I have a home built in 1954 and it has the old 2 wire outlets throughout the home.
I was wondering if I could run a green coated ground wire to the baseboard radiant heater.
The system runs in a continuous loop from and back to a modern oil fired boiler. It is all copper 3/4 with the aluminum fins.
I could either run a larger gauge ground wire out to a ground rod in the ground or back to the main panel.
Each outlet would be grounded no more than 24" max from the outlet to the ground point.
Now, reading the code is a little vague on this. Especially since that this system will always remain copper and never be "upgraded" to plastic.
What do you guys think?
This pains me a lot, as this is your first post, but rules are rules.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician, then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
