I have to ground to building steel in a project and I have used a rated beam clamp before that you tighten to the beam and the bolt breaks off when you have the right torque. Does this ring a bell with anybody?
Rob, the end of the metal conduit should also be grounded. This creates a shunt with this setup. They should have used PVC conduit for this ground run. I see this alot on the back of houses going to the ground rod. Looks pretty but is not compliant.
Unless someone see something here about the concrete grounding the EMT. That is what is so cool about this forum. The knowledge is endless on here.
Yes, it does ring a bell.I have to ground to building steel in a project and I have used a rated beam clamp before that you tighten to the beam and the bolt breaks off when you have the right torque. Does this ring a bell with anybody?
Holy guacamole!
That photo is of an isolated grounding conductor from a panel terminating to "building steel" in a federal office building. It's actually just attached to a piece of rebar in the ceiling above the panel. There are numerous violations in that one. :roll:
I have seen something that you've described in a high rise office building. I agree that it should be a listed product. Better than one of these.
ahh so Thats why its orange....
