W wmeek Senior Member Location Texas Occupation Electrician Jan 21, 2011 #1 Can you use a set screw type lug to bond GEC to building steel and to ground bar in a Gutter. Or does the code require a crimp style lug.
raider1 Senior Member Staff member Location Logan, Utah Jan 21, 2011 #2 Yes, You can use a set screw style of chair lug to connect to the building steel. Chris
