grounding transformer
ss electric1
nc
I ran across this today. 480 volt 3 phase transformer fed from MDP. transformer feeds 208 volt 3 phase panel.
transformer rated 1600 amps.
no ground conductors. transformer not grounded.
XO not grounded to frame. no grounding bushings on conduit.
I use to ground XO to frame. grounding bushings grounded to frame.
what is the proper way to ground transformer?
thanks for info.
ActionDave
Chief Moderator
Durango, CO, 10 h 20 min from the winged horses.
Licensed Electrician
thanks for info.
250.30 is where you need to look. You can bond the XO in the transformer or at the first disconnect.
