strugglinsparky
- Fort Collins, CO
I have to hook-up two mobile office trailers from one generator. The generator is a 38 KW single phase. The mobile trailers have a exterior panel, and have a 125 amp main breaker. I have been assured by the company that the big trailer draws about 80 amps with the air conditioner running. The mobile offices are expected to be in place for 3 months, but who knows.
My plan is to use 6-4 SJOOW with 4 wire Hubbell 50 amp twist lock to connect to the generator which has a overcurrent of 50 amps, and direct wire to the panels on the side of the mobile offices. It's about 30' from generator to trailer.
I believe this is a solid plan. My question starts when I start thinking about grounding and bonding. I know I should drive a ground rod at the generator, I however do not think I should drive a ground rod at the mobile office. The G.C. is demanding that I do. This is my first job with a this client and do not want to start off with friction. I think to appease the G.C. I will drop ground rods at the mobile offices and connect them each with a #6 bare copper bonding conductor. Am I right in thinking this. The job was a no bid and price is not that important.
Thanks,
Strugglinsparky
Thanks,
Strugglinsparky
