grounding two services
voltage37
Indiana
If you have two services of different voltages located on the same building side by side do you use the same grounds for both services? Or do you drive ground rods for each service and ground them separate. I think you use the same ground rods for both services.
Re: grounding two services
Section 250.58 requires a common grounding electrode system when two services supply the same building.
