grounding vs bonding
electrofelon
Cherry Valley NY, Seattle, WA
a quintessential question for this forum category........Say I have a piece of emt in between two pieces of sealtite (LFMC) Say that the sealtite is not an acceptable EGC due to the size/length/circuit OCPD per 250.118 so there is a wire EGC. Is this acceptable? What I am getting it is although we know the sealtite cant be the EGC, can it be the bond for the emt? How do we know? I see 250.96 but it doesnt get into what is an acceptable bonding path.
I kind of don't have a problem myself with allowing the flex to bond the sort of isolated raceway as you described.
But if you replaced that raceway in the middle with a metal box, cabinet, etc. it is pretty clear you would need to bond the EGC to that item.
How about something similar? Same LTFMC situation but a conduit body in the middle of a run?
Is the sheathing on MC any different than your set up? I say no. It's not not an EGC but it is required to be bonded.
250.96 doesn't come into play a all. It only concerns using metal as an EGC instead of wire.
I thought about MC where the sheath is not an EGC but is obviously acceptable to bond itself :)
but isnt that what we are doing in my example with the LFMC?
So where are the requirements different? Take Kwired's example of a pull box between the LFMC. Need bonding to the wire egc or no?
The difference is your flex/emt arrangement is not an Equipment Grounding Conductor, the wire pulled through it is.
This is one of the reasons I hate the idea of tossing in the word Bonding all around art. 250. It makes the simple idea of making sure there is a way to clear a fault more confusing than it has to be.
