AES1005
- Nitro West Virginia
I find a lot of load center's that have the neutral (white) wires and the bare ground wires on the same terminal screw. I know these are bonded together, my question is, could this configuration cause resistance issue's? The earth ground being 25 ohms if the path is kept series/parallel or would attaching these on the same bus bar same screw terminal matter?
