factoryrat
- Detroit
On this question you can choose more than one answer.
Exam Question: You are connecting power to a small pump house. You intend to use the metal well casing as a grounding electrode for the remote
structure and the casing is isolated from the house supply, a metal water pipe. You would -
a.) use the well casing as the grounding electrode
b.) must effectively bond the pipe to the well casing
c.) may not use the well casing as an electrode
d.) need to add a supplemental grounding electrode as part of the system
Help! I'm confused and could use some direction.
Thanks
Thanks
