james wuebker
- Iowa
Have outside pole lights(277v). All outside is ran it pvc that then comes into building to a 6x6 j-box. From the lights outside 1 hot, 1 neutral & 1 grounding wire. Now the feed for the lights are fed from a 20 amp breaker to the j-box. The feed has only a neutral and a hot wire and they are using the emt conduit for a grounding wire. The grounding wire from the lights are only bonded to the j-box. I believe this is code but where in the book do I find this. I don't like this method because you never know that if someone hits the conduit then it breaks away then you are without a ground. What do you think about this.
Jim
Jim
