Grounding wire through box
Dexie123
I'm looking for a code referernce (If one exists) that says when you have a grounding wire run within emt that you need to bond the wire to each box.
I have 3 circuits (2 different neutrals) going through various 5 inch boxes for lighting and power. All the piping is EMT.
Thanks
Thanks
If you have splices in the boxe you should Bond the EGC to the box but if you jus use the box as a pull boxe ,bonding the box is not require at that point!!!
