John Valdes said:Tip, With wire strippers start about 3" from end of wire. ...
I have tried it this way and it just doesn't work for me.tallgirl said:Is that a typo? I start about 1" from the end, strip about 3/4", then trim the excess insulation off, leaving about 1/4" of insulation to keep the strands together. Then, I grab that piece of insultation, squeeze, and give the wire a good twist to "tighten up" the strands, before finally screwing it to whatever.
Dave58er said:For one thing if I just leave 1/4" of insulation it always comes off when I do the back-twist thing that Marc talked about, then I'm just starting over.
paul said:I find these to be quite useful.
Dave58er said:I have tried it this way and it just doesn't work for me.
I start way back on the wire.
Also I strip a good 1 1/2" because half the time you tighten the screw and the wire will "roll" a bit so that if you only strip 3/4" you are left with some insulation under the screw. Once again, just back to starting over.
I'm sure I could get your way to work if I was being a little more patient and carefull but I'd rather give myself a margin for error. The only time I wrap a ground is on the plate for lay-in light fixtures, and with sometimes hundreds of fixtures I'm in a hurry and I don't want to do any twice.![]()
roger said:Julie, as far as an EGC or an EBJ is concerned, you could start stripping anywhere, even where it leaves raceway or cable connector.
Roger
ibew441dc said:monkey,
I would caution the use of just any type of washer for this purpose. There are washers that are manufactured for this purpose.
An AHJ might throw 250.8 at ya and say the washer (assuming fender or flat)
is not listed for grounding/bonding.
I know thats splitting hairs but I have met inspectors who are picky like that.
ibew441dc
e57 said:I have tried to train guys under me not to do that - common practice - as I see it as a violation of 300.14. They strip it right out of the entry and then right to the screw, and that counts as a termination IMO.
On topic, if worried about stranded - pigtail a piece of solid...
