barbeer
- Pinellas County, FL
Need opinions-
200amp 3ph 120/208 volt MLO panelboard has no ground bar and is using EMT feeding panel for grounding conductor.
100 amp 3ph 208 volt primary from above panel, no grounded conductor to xfmr.
480 volt 3ph secondary to paint booth.
No grounded conductor means non SDS.? therefore no electrode system needed at xfmr.
Somehow I feel a little uncomfortable asking that they bond the xfmr enclosure to EMT that runs from front of warehouse to back along steel framework- help me not feel this!
