Grounding
It is a grounding electrode conductor. Whether it is properly applied will depend on more information about the installation.
Is this a panel supplied by service conductors, or maybe the main disconnect of a building supplied from another building or structure?
Is it a panel supplied by other panel in same building? Or supplied by a transformer or other source in the same building?
I have a lighting load center. I connect a #2 bare copper conductor from the load center to a ground rod. Is this bare copper conductor called 'Equipment Grounding conductor'.
I agree with the other posters that it is a GEC.
Whether it is necessary, properly sized, or appropriate is something that we cannot tell from the limited information you supplied. Incidentally, in most cases if you are using a ground rod as your grounding electrode system, you will likely actually need to have two of them.
Which better describes the conductor?
Grounding Conductor, Equipment (EGC). The conductive
path(s) installed to connect normally non?current-carrying
metal parts of equipment together and to the system grounded
conductor or to the grounding electrode conductor, or both.
Grounding Electrode Conductor. A conductor used to
connect the system grounded conductor or the equipment to
a grounding electrode or to a point on the grounding electrode
system.
Article 100 is always a good place to start with this kind of question.
