JDB3
- San Antonio, Texas
In an area where I do work, there is no inspections. The utility company, for 200 amp services mount a combination meter/panel onto their pedestal.
We furnish/install the single bolt on breaker for it. There is no provision for a grounding wire.
We then install the wire from the panel to the house.
I install a #4 solid copper wire (sticking up from the slab to go into the panel at the house) to tie to the re-bar in the slab, stick out enough to tie onto a ground rod in the ditch (that has the conduit from the panel (on their pedestal) to panel (in this case) located in garage.
Since there is only a 3-wire feeder from utility power source, should the grounding wire @ the house panel be separate from the neutral bar or should they be kept separate? :?
Thanks in advance for the input.
