Grounding
Futurejourney
New User
Arizona
Hey everyone this is my first post and hoping someone can help me. I'm first year apprentice and just got my first solo job and need some advice. I have a portable welding table that im working on and i have to go through and make it up to code. This portable table has a 30kva 480/208 delta/wye transformer. I have 6/4 so cable with a plug feeding the transformer and i have #2xhhw on my load side going to a 90a main circuit breaker in a sub panel on the same table. I was reading the tables and i feel like i should use a number 8 for my ground wire to my ground bar inside the panel and connect it to my grounding lug thats connected by a jumper to the neutral on the load side. Is this okay?? Thank you.
I am closing this thread because as an apprentice this is not a job you should be doing and I fear there is danger involved
