MisterMoSparky
- WV
- Residential Service Electrician
Main Disconnect outside G-N bonded, 4-wire going into main panel, Main Panel has G-N bonded also. My customer called me out there to fix their landscape lights and one of their 600W Transformers had burned out. I recommended having their grounds and neutrals separated in the main panel. During a surge event, the over voltage that’s traveling along the ground and neutral bar in the main panel to eventually make it to the ground rod outside will slightly effect the low voltage electronics and lighting around the house over time. Is my thought process wrong?
