I see two facets to this job, and most of you have touched on them.
The first is your duty to perform 'due dillegence.' That is, to ascertain, primarily by contact with the appropriate agencies, that the job is legal. With that issue settled, it's on to the technical aspects of the job.
Your job involves growing plants, which means that you will face two primary issues: light and moisture. Secondary issues revolve around heat and venting.
For lighting, expect there to be lots of lights, and various timers to control them. Light placement can be critical, as plants will 'bend' towards the light. There's a very good chance that HPS - the ugly yellow light- will be used.
If any sort of HID lighting is used, there will be significant heat generated, and you will want to stgger the switching times. If the site has 3-phase power, harmonics can be a concern.
Moisture presents itself as an issue in obvious (irrigation and water handling) as wll as less obvious ways. Each plant will 'exhale' about a cup of water into the air every day. This moisture, and the various fertilizers, etc., used, can create some areas that are corrosive - especially to aluminum "Bell" boxes. Any 'cool' spots will have condensation issues. Consider this especially when siting your controls and panels.
Remember that the inside of boxes on the outside walls will likely be where moisture condenses. You'll never be able to keep all this moisture 'out;' far better that you design everything to drain. This might mean you drill 1/8" 'weep' holes in bottom corners.
Codebook aside, I've seen a number of agricultural situations where "Romex" served in flexible applications better than SO cord. It appears that the rubber insulation quickly rots away, where the PVC/nylon of the NM does not. A typical application would be for a partion that gets swung aside for cleaning. Remember what I said about aluminum boxes? The same corrosion issues can eat up the jacket on MC.
All of this points to a need for an engineered HVAC arrangement. You'll likely have to power a variety of fans and the like.
All the above is equally true, whether you're growing tomatoes or "weed."
Then, lest we forget .... security. Plan on there being alarm wires and such run to everything.
