iwirehouses
This is a very small garage that someones turning into 1 room apartment with a small bathroom. Its maybe 15' x 10'. It has cooking provisions, but thats about it.  Can I bring it  a 60 amp sub panel?  I could bring it 100, but I plan on doing the entire run (through the houses basement, through the ground, into and up through the roof rafters to the opposite side of the guest suite) in pvc conduit.  So the smaller the conduit I can use, the easier, as far as drilling top plates, etc.  I don't see any codes in the nec about guest suite services, so I imagine as long as the load calculations come out right, there is really no guidelines on a service for a guest suite.  Am i correct?
