Re: Guitar amp.
So are you in or out Matt? You sound like you're in.
I have to argue about noise being the cable though. When I had cheaper stuff I tried everything in the known universe to fix it at the cable, all to no avail. Man did I hate that noise.
Well that splains your noise knowledge Wayne. What about balanced lines? Impedance matched transformers at both ends, two signal wires between the transformers, induced noise really cancels just like the EMF canceling in the 3way threads. DIN connectors. I've only played with those configurations. I assumed the pros must use those.
Did you ever get a chance to just goof off for a bit with someone's guitar with like 200 decibles worth of Marshalls on the overdriven input with the gain all the way up and just gobbs of distortion and harmonics are flyin all over the place and the feedback makes every note you stop on twice as loud and I'm sittin here making those Tim Taylor grunting noises and my girlfriend's looking at me like whatever it is I'm doing I should stop it.
Sorry, I got a little carried away.
Editted to use Matt's name.
Edit II: You are right though about the cable Matt in that the balanced line removes a lot of noise. But sheilded is sheilded.
[ January 23, 2005, 05:15 AM: Message edited by: physis ]
