After searching the forums for a while i wasn't able to come up with an answer to my questions regarding gutter vs pull boxes vs wireways.
My confusion is when does an auxilly gutter become a pull box, what defines a pull box? When sizing a pull box by 314.28 the size would have to be so large it would be very impracticle, assuming the conductors are #4 or larger and the conduits are 2.5".
Why cant, or can i, use a gutter sized according to 1 wire per terminal, instead of using the 2.5" conduit at 6x + the sum of all others on the same wall. If i required a gutter with 3 2.5" nipples and 3 1 1/4" nipples leaving one wall by 314.28 it would have to be 26 3/4" wide.
a little help would be greatly appreciated.
