Fulthrotl
~Autocorrect is My Worst Enema.~
- E
you just have to love this fine example that i brought for show and tell.
bad ballast, shut off both ballasts, and then find the mystery guest.... a
separate circuit using the ballast compartment as a raceway.
#12 in, #12 out, at the other end of the fixture, so having #12 running the
length of the fixture would look pretty obvious, so they employed stealth
technology, and used a couple #18 fixture wires, and wagos to hide the
feed thru. 12 to 18 and back to 12.
fixture was 277, mystery circuit was 110. all the neutrals were under the
same wirenut, probably to dampen harmonic thrust of the oscillator...
hack, hack, ptui!
have to go back in the morning to remove offending circuit, and make sure
interrupting it won't shut off their file server or something. it probably will.
