uwireme
- Cottonwood, CA
Yeah, you can tell because the wire sizes are the same. ;^)If you look real close you can see that the loads have been precisely balanced to have no net neutral current for the panel.:grin:
There ya go. Now you just need to send in a patent for a wire-saving device. Catch phrase: "Tired of wasting money on all that neutral wire? We can reduce the size of your neutral by up to 100%".The time clock is used to balance the loads. By a precise and judicious cycling of phases a perfectly balanced load can be achieved. I've done it a million times.
If the bonding screw is in place, the conduit is helping. :roll:
