Just curious if anyone has come across an issue with lights fluttering while a hair straightener is plugged in to the same circuit? Situation: '60's style home, panel 12 yrs old, single ground rod, 15A circuit from a sub panel. The lights in the bathroom will dim slightly and somewhat quickly, this does not happen with a 1500W hairdryer nor a 1500W space heater. These all should be resistive type heat correct? The plate on the hair straightener says 165W (more than likely 1650W and the 0 was left off). Voltage is 121-122. Neutrals tight. I moved the breaker up in the panel and then moved it to the main panel - no change. The only time we see it is when the straightener is fully on. I have read on here posts about losing the neutral back to the transformer creating similar situations, could this be related? I would not think so since the problem seems isolated to one circuit.
Thanks for the help!
