larry dimock
- Washington
Why aren't 1875 watt household hairdryers required to have their male cord end be the 20-amp configuration?
Why do you see a need for twenty ampere receptacles?Originally posted by bphgravity:
This is why it is so important to meet the requirements 210.11(C)(3). Bathrooms are rapidily becoming one of the heaviest loaded rooms in the home. It is a good design to dedicate a 20-amp circuit with 20-amp rated receptacles and to feed no other outlets, even if it is a single bathroom. This is certainly not required, but certainly meets the minimum and then provides what is really needed in todays bathrooms.
