emf10
- Southeast PA
These are plastic standoffs that hold up to 5 nm cables. I'm using these to attach Romex to metal studs (single family dwelling). They are listed to comply with 300.4d, but will they also meet the requirements of 334.30? The packaging says "For positioning only" what exactly does that mean?
(334.30 - Nonmetallic-sheathed cable shall be secured by staples, cable ties, straps, hangers, or similar fittings designed and installed so as not to damage the cable at intervals not exceeding 1.4 m (41/2 ft) and within 300 mm (12 in.) of every cabinet, box, or fitting. Flat cables shall not be stapled on edge.)
If not what is recommended to satisfy 334.30 when using metal studs? Tie wraps with a hole for a sheet metal screw? I would rather use some type of standoff though.
