John@FL
- Sarasota, FL
- Design Engineer (AV / Home Automation)
Hello, I am designing a Lutron QS panel based lighting control system. I am using (mainly) Lutron DIN rail breaker panels with a mixture of dimming, switching and 0-10 modules. I also need to have some receptacle circuits on dimming modules (using Lutron specialized receptacles and matching plugs as required). However, I am being told by a lighting designer that the receptacle loads must be attached to a 'feed thru' panel as opposed to a 'breaker' panel "... to comply with the NEC". I can not find anywhere in the NEC that indicates this; also, I do not see a logical reason why it would matter. I want to run main feeds to the breaker panels and then individually 'protect' each dimmed or switched load via the panel breakers. Can anyone explain why I would need the feed thru panels (and any NEC reference)? Thanks in advance.
