fifty60_4802GND
- Ohio
- Engineer
Several years ago I had an argument with someone about turbine flow meters in CID2 areas. The flowmeters have a hall effect sensor installed on them that sends counts back to a PLC. There are no explicitly CID2 labelled versions of this hall sensor/pickup, only IS versions and explosion proof versions. I don't think these pickups would need to be IS or Explosion proof. They are not current interrupting, and their temperature is well below the ignition temperature.
Short of sending these in to UL/FM/Intertek for evaluation (which I may look in to actually), what would I need to do to justify using them in a CID2 area? Can you please point me towards the code sections I would use to make this judgment?
