KVA
- United States
Finishing up this hellish job and part of was installing 12 recessed lights 6 in each room. After all said and done they start flickering when you dim them and sometimes they don't dim hardly at all.
Started out with **** lutron $12 dimmer then swapped it out with another **** levitton. Both were 600 watts. I used br65 philips halogen bulbs.
I did a test with some regular incan bulbs still flicker. I took 5 bulbs out and left one in and it seemed to dim fine.
So at the end of the day i just took out both dimmers and put a toggle in. Never a blink.
They do have a **** (big) load on one 15 amp circuit and in one 3 gang box they have at least 6 maybe 7 neutrals twisted together.
Would it be the neutrals causing the problem with the dimmer? Or would a 1000 watt work better? Or different halogens?
Weird the lights flicker in both rooms when operating the dimmer. It also doesn't seem to start right away maybe after alittle while of use.
I dunno looks real unprofessional right after they compliment my work then this happens:rant:
