halogens
depatie
I installled some track lighting with a dimmer and now it has a loud hum. The bulbs were the mr16 small halogens. How do i fix it?
Re: halogens
You should also determine if your transformers are electronic or electro-magnetic. If they are electronic (which is likely since they are making a noise when you try to dim them), then Hurk is right - you need a special dimmer. Be ready for price shock.
Steve
Re: halogens
If halogen lamps are simply incandescent fixures with a different inert gas than standard incandescents why do they need a special dimmer?
Re: halogens
Follow the link spsnyder gave and under the question "How do I tell magnetic and electronic low voltage transformers apart" follow the link to application note #19.
Steve
Re: halogens
Make sure you have a low volt dimmer and make sure the transformer is loaded correctly if it is less than 80% capacity there will be a humming issue.
