I have a question although it may not be related to NEC, I would like to find out where I can find out the answer if you guys know.
This is about fire protection.
I am working on O'Hare Airport Elevator Modernization project, where there is an existing Halogenated fire extinguisher suspended from the ceiling in the elevator machine room. The Department of Aviation is asking the following:
"Can you check whether Cease Fire halon (ozon-depleting)-based fire suppression systems in these type rooms (elevator machine rooms) are recommended, accepted or even allowed by NFPA without an accompanying audio/visual alarm?"
This existing extinguisher has a module space that needs to be installed and tied to the fire alarm control panel. Do we need this module to tie to fire alarm sysem?
