ericfox
- Akron, Ohio
Hey guys,
I noticed the ceiling fan in both my kid's rooms are a bit wobbly. I wondered if the old home owner installed the correct hanger to mount the fan. I attached some pics of what I found in the attic.
I'm 99% sure the hanger and box are not rated for the fan.
I can access the attic space without too much difficulty.
I'm thinking to install a cut piece of 2x4 between the trusses with 3" screws from each side, screw in a pancake box from below, then wire the fan in the new box.
****EDIT***** there is an ABS pipe on one side next to the truss so that idea won't work. How would you guys go about it in this case?
Thanks a lot,
Eric
Thanks a lot,
Eric
