I was asked to perform a test on the static grounding receptacles in a hanger on an army base. They are going to replace the receptacles and want me to test before and after to make sure they are at least equal to exitsing.
I called the maintenance contractor that does the annual testing to get the procedure they use and the only info they would give me is that they use a megger and test to building steel. I have spent hours on the internet trying to come up with a standard testing procedure and have come up with zip about using a megger. I did a few with an ohm meter and came up with readings between 10k and 30K ohms and with the megger on 500V get 0 ohms.
The test reports from the maintenance company all just say less thea 1K ohms.
Any suggestions or advice would be greatly appreciated.
