T tvo Member Dec 1, 2009 #1 Hi, Does the NEC prohibit hanging 75KVA transformer>? What section of the NEC prohibit hanging transformer over 50KVA? Thanks a lot for the tip,
iwire Moderator Staff member Location Massachusetts Dec 2, 2009 #2 No the NEC does not prohibit hanging any size transformer. A 75 is not odd at all and I have hung 300 kva transformers.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Dec 2, 2009 #3 I believe that you're thinking of hanging them above a hung ceiling. That limitation, 50 KVA, is in 450.13(B).
nyhockey Senior Member Location long island, ny Dec 2, 2009 #4 In NYC space is a premium almost all transformers go up in the ceiling.
T tvo Member Dec 2, 2009 #5 You are right. The limitation of 50KVA is for above ceiling. In this case, we don't have ceiling in the electrical room. Thanks infinity said: I believe that you're thinking of hanging them above a hung ceiling. That limitation, 50 KVA, is in 450.13(B). Click to expand...
W W6SJK Senior Member Dec 4, 2009 #6 No NEC limits but if you happen to be in a seismic area it could get complicated/expensive to hang it.
