I suspect you are just trying to pull someone's leg. They don't have to be on an AFCI circuit unless they share that circuit with one or more bedroom outlets.Originally posted by raider1:P.S. They also need to be on an AFCI protected circuit.![]()
The ones in the bedroom do, but the ones in the kitchen do not need to be on the same circuit. I agree with the way Al described the distinction.Originally posted by peter d: Charlie, if the local code requires smoke detectors in every bedroom, then they need to be protected by an AFCI.
Thanx, Chris.Originally posted by raider1:
LarryFine makes a good point.
Here we are not required by WAC exception to put the afcis in bedrooms on afcis.The logic is that you always want the afci to operate independantly of the afci.
The ones I have seen are battery back-up and would operate without 120V in the case you have described.If the smokes are on that circuit then you then of course have no smokie protection.
I think all the regulars here are working off the 2005, so the unofficial agreement is that all references are based on that.Originally posted by LarryFine:
I suggest we add the year to NEC article references, such as "'02 - 210.4"
Gee, I consider myself a regular, and we use the '99 here in Va., as of 10/1/03.Originally posted by georgestolz:
I don't have a 2005 in my house, so whenever I quote code I do mention 2002 in my references.![]()
