Hardwiring Dishwasher
JoeNorm
WA
Can I hardwire a DW under the 2020 code? Is all that is needed a lockout on the breaker? I need more characters so I am continuing to type
2023 NEC
422.16(B)(2) (1-7)
Wire it either way.
You can find plenty of characters here in the forum, just keep reading.
Oh, you mean typing characters. Sorry.
Thanks for reading.
Comments accepted.
TX+MASTER#4544
I've seen it discussed various ways, 210.8(D) requires the OUTLET that supplies the dishwasher to be GFCI protected. If you run the NM straight to the dishwasher connection point... is that considered an outlet ??
Locally inspectors require the breaker to be GFCI.
pot meet kettle :)
TXMASTER....
pot meet kettle
I've never heard that one before, that's funny!
I'm more familiar with"....jumping out of the frying pan and into the fire".
That fits my personality very well,... at times. Sometimes I have two mouths and only one ear. Say's my wife. True. She's the brains.
Augie, you have been here way longer than me. The "outlet" discussion has been done more than once in my time.
From 2017 NEC Outlet. A point on the wiring system at which current is taken to supply utilization equipment. (CMP-1)
So yes the connection of the romex to the dishwasher is the outlet.
Art. 422.5 does not mention plug in or hardwired so gfci is required regardless
422.5 Ground-Fault Circuit-Interrupter (GFCI) Protection for Personnel.
(A) General.
Appliances identified in 422.5(A)(1) through (A)(7) rated 150 volts or less to ground and 60 amperes or less, single- or 3-phase, shall be provided with Class A GFCI protection for personnel. Multiple Class A GFCI protective devices shall be permitted but shall not be required.
  • (1)
    Automotive vacuum machines
  • (2)
    Drinking water coolers and bottle fill stations
  • (3)
    Cord-and-plug-connected high-pressure spray washing machines
  • (4)
    Tire inflation machines
  • (5)
    Vending machines
  • (6)
    Sump pumps
  • (7)
    Dishwashers
There was a homebuilder that I used to do work for years ago in Orlando. I think it was David Weekley Homes. They had a single-pole switch drawn on every plan as a dishwasher disconnecting means because we hard-wired all of the dishwashers.
I put a switch (toggle type) under the kitchen sink and then run directly over to the dishwasher unless its a Bosch or some other fancy foreign unit that insists on a plug in via a secondary box araingment they annoyingly supply with their dishwashers. The gfi protection is done at the panel with a dual purpose afci breaker.
Did you mean dual function breaker, or is 210.12(A) amended out in Tennessee?
My error.. yes dual-function... TN has some added exemptions to AFCI but dishwashers are not among the exceptions.
