AZsparky
- Scottsdale, AZ
If you hardwire a Low Voltage Lighting transformer located outdoors, by NEC does it still need to be on a GFI protected circuit?
Thanks.
Thanks.
The transformer has been swapped with a temp one that had no problems with a gfi receptacle where it was located. Once swapped however the GFI in the problem area still tripped about every third day.
I bet the trany is bad.
Found that little gem located just above the garage attic access opening in a residential foreclosure property in Scottsdale, AZ. I was there to do remedial work for the new owner. Somebody spliced #8 AL(dryer feeder) to CU#6 THHN(3' splice), Used CU wirenuts, then finished it off with grey phase tape. You can see where the arcing was doing a little wood burning. The insulation had actually bubbled on the AL cable from the resistance generated by this setup. If this was insulated space, I think a nice attic fire would have occurred. I'm guessing this was done because the cable was probably damaged by things stored in this space.
