do i need to count the neutral of a 3 phase 4wire transformer secondary of a delta-wye system as a current carrying conductor per 310.15(b)2. their is a code right under the 310.15(b)2 table (i dont have the code right in front of me) that states if you have a 3p 4w wye system where the majority of the load consistes of non-linear loads, harmonics are introduced, and the grounded conductor shall count as a current carrying conductor. so more then 50% of the loads i will be supplying are LCD computer screens(just the screen, not a computer) and low voltage LED (light emitting diode) lighting, which is powered from class two power supplies and electronic contol boards.
my load is about 450 amps. Is the non linear load something i should be concerned about with a load of this type and size? I will problably count the neutral anyway and derate, but i would like to here what others have to say.
