Re: Harmonics
I thought Even Order Harmonic Distortion (2nd, 4th, 6th...) was an Audio issue...???
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
:roll:
Triplen (?3 of fundamental Hz and equal increments thereof) results in nastyness within the common conductor of a 4 wire 3? Wye's multiwire branch circuitry, when THD is >20% per Line (worst cases found at 33% +).
These Hz would fall at crossings of 60Hz ? 3, 180Hz ? 3 and 360Hz ? 3, and every third multiple afterwards.
The 1st / 3rd Harmonic point - at 180HZ, is where 60Hz ? 3 and 180HZ combine. Others combine in a similar fashion throughout the spread.
Not sure if even order Harmonics will exist on an AC, or if Odd order Harmonics will exist in an Audio (Sound) wave. If anything, they will be of very low amplitude.
Just my 2?...
Scott35
