Back in the early Eighties, I was brought in to upgrade a gutted two story Victorian that had been built as a modest duplex in the very early 1900s. The overhead drop hit the high gable end and immediately went into the wall. But the black paint metal boxes housing the two services and the meters were in the basement, high, above six foot six.
The service conductors (attached to the overhead drop), ran down in the 2 x 4 wood stud walls, from the gable, through the second and first floor outside wall, and popped back out into air just under the first floor subfloor directly above the meters.
These #12 copper RW unfused service conductors were run on plain old porcelain posts and through porcelain tubes as needed along the way. The first overcurrent device was the one 20 Amp fusestat after the meter on the load side of the service disconnect knife switch. The neutral screw shell in the knife switch was populated with a screw in short.
The house had a pair of 120 Volt 20 A services, each supplying two 15 Amp branch circuits.
Being gutted, and owned by a young guy, the house became a single family with a 100 Amp service with all new wiring.
I have always been absolutely amazed that there was no sign of overheating anywhere along the "service" conductors.
