why not just block it out enough so that it will appear to be surface mounted on the brick. That's what we used to do on some of the homes that we did when we had our meter base up before the brick. We'd make a frame out of 2 x 4's to stand it off the wall.This is going to be a remodel of an apartment complex. This a mutli meter can and they want put brick out from the exiting block wall and meter can will be flush with the brick.
agree, most POCO's would not allow. To me it is also a violation of 230.70(A)(1) although we could argue "inside"You have to check to see if your PoCo rule book allows it.
How is the service cable supposed to get into the enclosure?This a mutli meter can and they want put brick out from the exiting block wall and meter can will be flush with the brick.
How is the service cable supposed to get into the enclosure?![]()
This was done on houses here many years ago, No service cable but a service mast that went up between the brick and the framed wall thru the roof.
I am surprised that someone from California hasn't said something. Some of the areas there do it all the time.![]()
We do it all the time. PG&E doesnt really care about anything lately.
~Matt
Well, reconnecting might take two weeks. But hey, everyone else had electricity?
..speaking of that does your AHJ have anything to say on that subject?
Firstly, I have never done an install like that. It was done years before I came on the scene. Secondly, I don't think it would be an AHJ call. Thirdly, with everthing underground and the large conduit that the POCO uses you can see it being a nightmare.
I have not seen a new install like that in my 30 years here in NC.
This is the trouble with written posts. I did not take your post as a stab at me. Since I explained it earlier I just wany=ted to clarify that I never did it, etc. Sorry if my post came across negative to you. It, honestly, was not meant that way. Funny, I just thought I was answering your question. :smile:It wasn't a stab at you.
