Dsg319
- West Virginia
- Wv Master “lectrician”
I know to change rotation on a 3phase motor you obviously flop any two leads.
Well instead of doing it in the pecker head today I done it in the VFD cabinet. It is all factory wired on line side and load side of VFD with special termination kits so I had to swap it on the load reactor after the VFD.
I swapped two of the leads on the load side (motor side) of the load reactor.
Than a co-worker suggested I also swap the same two phases on the line side of the load reactor.
It was early and I agreed with him as he saw the different colors of phases beside each other and thought it would short circuit.
But now that I’ve had time to ponder I believe the motor will still run backwards from swapping the line side of the load reactor after swapping the motor load side leads.
It should have been just swap two phases on either side of the reactor and not both right?
