Hazardous Location?
I have a simple question but yet it is one I am have trouble finding the answer to. So here it is: Is a municipal sewage lift station a hazardous location? I am in search of the answer because I have worked on several stations that run the floats right up into the cabinet, but the other day I was working on one that had a intrinsically safe isolation barrier for a float that had failed closed which was running the station dry because it happened to be the high level float. I guess from what I have found so far is if it was a hazardous location it would fall under the class 1 area but I want to see it in black and white, can anyone help?
You have my interest. I have done many and used nothing more than duct seal in the enclosure. All past inspection, and to the best of my knowledge, none have blown up.
That is all I have ever done and up until a few weeks ago all I have ever seen done. I am trying to find out if it is code to use these barriers or if and an Engineering firm is selling a bill of materials that really in a sense is over engineered.
You will find it in
NFPA 820
Standard for
Fire Protection in
Wastewater Treatment and
Collection Facilities​
