HD AC cable connectors Junk.
A few different manufacturers make that style of connector, probably whatever patents AFC Cable Systems had ran out.
Eddie mentioned Home Depot carries Halex and there actually is a Halex part number for them;
If buy set screw, you mean the older type with just a screw then they can't be used on aluminum. The one screw saddle type has a foot under the screw to press against the cable armor.
That's what I was getting at, type where the screw makes direct contact with flex to secure it. Pretty sure that type never been acceptable for use with aluminum flex.
