HDPE Conduit/Tubing
cycotcskir
Since there is no topic for Materials, I guess I'll just ask here. I have some HDPE 12" conduit left over from a directional bore that I want to use to make some waterproof containers.
Do they make endcaps for this size pipe or even threaded ends?
I know that there is a special welding machine for this conduit and they weld a pulling cap on the end, but I have never seen a regular cap.
I have never purchased this conduit and I am not even sure where to purchase something this size.
I can get the full specs of the pipe later, but any suggestions would be appreciated.
Oh, and I also have some 3" that I might be able to use, so I would need caps for that too. I assume this would also be purchased at the same place.
You may be able to get a cao for the three in from a plumbing supply. But the big one you may have to weld it.
What are you going to put it the container? Just curious.
I was thinking of making a waterproof sealable container for dry long term storage. Possibly put in some silica to keep out the moisture. There are many uses and the 12" would allow more uses.
