Why PVC coated?Welcome to the forum.
How about PVC-coated rigid steel?
IMO, if it is in the slab (not under it) and over a moisture barrier, it doesn't need to be RMC or corrosion protected, IMO.EMT with the proper corrosion protection.
Personally I would use RMC
To take it another step, if the receptacle is on the critical branch it can not even be installed in a flexible metallic raceway.
And I agree.IMO, if it is in the slab (not under it) and over a moisture barrier, it doesn't need to be RMC or corrosion protected, IMO.
