Dalehaldeman
- ATLANTA, GA.
Can You Use Multi-wire Branch Circuits In Patient Care Areas?
mdshunk said:Yup, but it's bad design for this sort of duty, in my opinion, considering the recent code changes related to MWBC's
In a nutshell, nobody likes you much.76nemo said:Now, would anyone of you like to share your views? I brought this up about two months ago, and it was shot down without explanation. I am not one to argue.
mdshunk said:In a nutshell, nobody likes you much.
D )
Don't know much about that. I just don't favor the idea of turning off two circuits to work on one in certain settings.76nemo said:Electronics, harmonics, and overheating issues. Remember now???
iwire said:I will be glad to ramble on about MWBCs,
roger said:Electronics and their associated additive harmonics are of little concern.
How many overheated MWBC neutrals truly attributed to the above items have you repaired?
Roger
You wouldnt be saying that 15 yrs ago when they were starting fires. When the 4 wire of a lighting circuit was too hot to touch.roger said:Electronics and their associated additive harmonics are of little concern.
Roger
76nemo said:This is where I did not want to go. To answer your question Rog, none,....zippo.
quogueelectric said:You wouldnt be saying that 15 yrs ago when they were starting fires. When the 4 wire of a lighting circuit was too hot to touch.
76nemo said:My point was the same as Bob's and Marc's, this is where I would not choose to use them.
