I have a 60W power supply.  The spec sheet says that it is 83% efficient, draws 1.7A max on the input at 100VAC.
1.7A * 100 = 170VA
170VA * (1 - .83) = 28.9VA
170 - 28.9 = 141.1 VA
The power supply is only 60W. I would expect that after doing the above calculations I would end up with 60 instead of 141.1.
So, out of the original 170VA, how much is lost as heat? Do I need more than the efficiency to calculate this?
Is 28.9VA being lost as heat, or is 110VA being lost as heat (170-60)?
			1.7A * 100 = 170VA
