- Chapel Hill, NC
- Retired Electrical Contractor
Okay so what does a 100 watt heat lamp do that a 100 watt flood would not be able to do-- I am talking heat not infrared stuff? Does it really put out more heat and if so how?
what type of flood lamp are you talking about comparing to the heat lamp (indoor, outdoor)...?
The only difference would be how the infrared is directed. It looks to me like the ceramic lamp would radiate in all directions, whereas a PAR style lamp would focus more of the energy on the area in front of the lamp..
Absolutely. As long as the reflector surface is efficient for infrared.I'd be a little curious if a spot bulb might direct heat more narrowly like it does light, compared with flood bulb
I would probably determine what I would want to heat - the air, or the stuff
Infrared will not heat the air, per se, but instead heats the stuff it shines on. The that stuff heats the air
A hot light bulb will heat the air, then the air will heat the stuff.
R-factor can come into play, draftiness, etc.
fwiw, I wired a restaurant last winter without any heat. Much of that time it was about 5-10 degrees inside the building. I used the walk-in cooler for my materials hut, and heated it with a 150watt work light (square, with tubular lamp)
That room was probably 90-95 degrees after being on all night with the door shut.
I'd imagine a well house won't be insulated quite that well, though.
Is some heat tape and insulation on the pipes an option?I would bet it does but the idea is to get heat a bit more wide spread than a spot. The problem here is that the wire is only 14 awg and the pump is 120v and nameplate is 14 amps. Now this isn't a problem but she has a water conditioner- runs only at night, a flood light and a light bulb in the well house....
There is i9nsulation on the pipe and heat tape may be an option. The problem is that there are pipes going to the well, holding tank , water softener system etc. It would take a lot of tape and I am afraid too much amperage. Right now we are doing a quick patch job for a month or so till we get out of the pipe freezing weather.Is some heat tape and insulation on the pipes an option?
